LGV-XFIRE
I got the 74mm TB and the bigger MAF. That might be what's needed. If you get the new MAF, you will need to use the old sensor so that you don't have any more problems.
Also, HOW THE HECK DO YOU HAVE A 2004 WITH 17000 MILES?
What sensor are you referring to when you say "old sensor"? I know Needswings sells the larger MAF housing and upgraded MAF sensor but I figured with that upgrade, the original wouldn't be reused. I also think it's possible that the 74 mm TB I ordered could've been damaged because I talked to a gentleman who performed the same upgrade without the accompanying MAF sensor and housing upgrades. To answer your question, a Vietnam Veteran had it in PA, but he couldn't drive stick for many years because of Agent Orange. It sat in his garage until he decided to put it on Facebook. I got it with 15.5k on the clock, I've put over 2k miles on it, and I intend on driving it until it is no longer able. That is, unless the right offer is made...
