Old Oct 17, 2020 | 12:40 PM
onehundred80
Default Re: Hub center rings measure
Originally Posted by Astrofriend
Sometimes when I mount off and on the wheels I afterwards could get vibrations when driving at higher speeds. They are correct balanced and I suspect that the hub center rings are bad or of wrong size.
Some documentation from when I investigated this:
2005 years Chrysler Crossfire: Hub center rings, part 1
Bad center rings can get the wheel a little bit off center and cause vibration at higher speeds.
/Lars
The photo showing the use of a micrometer used backwards shows why you get a smaller measurement.
The flat part of the micrometer does not touch the curved surface of the wheel bore.
Use a inside micrometer or old fashioned inside callipers and carefully measure them with a vernier.
