Thread: Battery Drain
Old Oct 25, 2020 | 02:30 PM
  #61 (permalink)
GraphiteGhost
Default Re: Battery Drain
Originally Posted by Bladez101
Im new to this forum but have found some really good advice on here..
I also have a battery draw but have found out the culprit but need advice on how to fix it.?
Both my Electronic digital clock and Outside temperature display backlights(green) stay on after i leave the car..if i pull the fuse regarding these the draw vanishes..
I have left the car for hours and gone back to find them on still
No other interior lights are on
After looking aroung this forum i purchased a battery cut off plug which works but not ideal.
Any advice anybodu might have to sort this problem would be much appreciated..
Cheers, Darron
Hi Darron welcome to the forum! This post is an old post (almost 4 years). Your particular problem doesn't mirror it (without me going through the entire 60 posts) yours. My best advice to start with is to create your own post so others can work on YOUR issue directly (not needing to 'back-read' this entire post). This works best as there is a fresh start. I have never seen this issue, so again create your own post and relay everything you mentioned in here INCLUDING if this problem just popped up, was with it from the beginning, or if you 'modified' something and it showed up along the way/noticed it afterwards. Good luck, and welcome!
