Old Nov 2, 2020 | 06:54 PM
pizzaguy
Default Re: locking/unlocking system
Originally Posted by leroyvette
Pizza Guy I believe mentioned that the pump would only run if activated by the lock/unlock dash switch , or key fob buttons.. My concern is that this does not appear to be normal operation--PROBLEM ???
Originally Posted by 2005 Ragtop
Alcon,
1. Assuming the driver/passenger doors are locked prior to exit, simply pulling the interior door handle will activate the lock/unlock pump and unlock both doors. I suspect the "you hear the pump run 5/6 seconds" is actually a leak in the pneumatic airline at or near the door handle actuator. Over time they get brittle/worn.
Tim
Tim points out a reason the pump would run. There is another thing that happens: If the car is sitting, locked, and you press unlock, the pump runs and unlocks the doors. IF you DO NOT open a door, in a matter of I think 20 seconds, the pump will automatically relock the doors! This has caught some people off guard, including me.
I do find it odd that you hear the pump run for 5-6 SECONDS, that is a LONG time and is simply not normal.
