Old Nov 4, 2020 | 11:27 AM
Romad's Avatar
Romad
Default Re: (1st Post) Bought 2006 Crossfire
No, you need not unbolt anything. If the beam is 45degrees down from strait ahead, someone has placed the bulb improperly. It is easy to screw up, I only replace bulbs with the lights on, about 5 feet from a garage door - makes it easy to seat them properly.
It was fine yesterday? Sounds like tire pressure to me.
It was not a problem cause mine is a base Crossfire and not blowers in that area. Problem was the former owner had removed the bulb securing spring and turned it upside down and was not holding the bulb in the housing hole. Just floating around. It's good now! Thanks
Loweredt cold tire pressure from 35 lbs down to 32 & 33 respectively. Haven't had a chance to drive it yet.
