Romad
Busy day with the Crossfire today. The new air filter sealing doughnut arrived and installed it. Washed and waxed the car and found a few flaws I hadn't noticed before. Nothing monumental just some little irritants that need fixing. Looks like the hood will need clay baring while the rest looked/felt ok. I saw on YouBoob where someone showed how well "Off insect Repellant" will help with fogged up headlight lens. "It worked" although not perfect, it was a quick temp fix. I hope to get them sanded down tomorrow with 600 grip first, then 1000 grit last and apply two coats of clear coat.
Where' the paint code located. Is it included in the VIN number?
If you want to remove the “haze”on the headlights, Mothers mag and Aluminum wheel polish works great
lots of tips on you tube
