Jim Holian
ZX2 Nick - Really, just the easiest for you to rely to. I guess, how did you make them, and what material did you use, and do you still make them. They appear very attractive in the photos. I had thought of using the faceplate from a SLK 320 gauge but you can only get them by buying the entire gauge cluster and the salvage yards think they are made of gold. So that idea is out! At my age I probably should leave well enough alone and stay with the stock gauge faces except they are hard to see in the bright sunlight. Another old age plague. Anything you can tell me will be just fine. If you make them, can you make them white faced?
Thanks,
Jim
The SLK230 and the SLK200 cluster faces will fit just fine, the only difference being the redline placement on the rev counters of the l4's vs the V6's (6250 vs 6000). Both have 80mph on the vertical as opposed to 90mph on the SLK32 and 100mph on the SRT6 respectively
I butchered the SLK clock window because I needed it lol but for comparison:
HTH
