zip439
Ref Brake noise. After parked overnight I often get a squeal from the brakes while backing from the parking spot, which in my case is from the ceramic pads. Once they clear the rust from the over night exposure all is well. You may not need new pads.
I hope you saw the rims on your wheels move when wiggled by the alignment shop and I would want to look at the bushings on the control arms while they are wiggling. I wouldn't trust them on a telephone conversation. My 2005 has 138,000 miles with no problems as to bearings.
PS the hub bearing end play is adjustable by tightening up on the hub nut.
Yes I did see it for myself. I / we did look at the control arm bushings and they are good. The mechanic told me the hub nut was not adjustable!! That is what I thought was wrong initially.
