Old Dec 4, 2020 | 10:38 AM
pizzaguy
Default Re: Head light aiming
Originally Posted by DirtyDen8810
I have a need to adjust the aiming of the headlight on my 04 coupe. The outboard head light on the right side is way too low. The other three lights are perfect.
WRONG. The adjustment bolt moves ALL lights together in that assembly - that won't do you any good!
You put the lamp in wrong. We all deal with this eventually.
1) Pull car up to garage door, about 3 feet from it (a wall works, too).
2) Turn headlights on.
3) Release the little retaining wire/clip from the bulb.
4) Reseat the bulb while watching the beam hit the wall/door. You will know when you get it right.
5) Relock the clip when you get it right.
