Alarm / anti-towing issue
I'm new to all this so bear with me. I have a 2005 roadster with alarm/towing issues. I recently towed it when the transmission went out. While on the trailer the anti tow alarm went of, shut it off and all was well. When I got it back from the transmission shop I jacked it up to change the oil and when I went to start and leak check, nothing. It sat there for 24 hrs and I just happened to stop and try it and it started. It was good till I jacked up and repaired rear tire leak. Now no response when I turn on the ignition. During this time the alarm has been going off randomly to the point I had to disconnect the battery. I don't know if this is an anti-towing issue or a scream module issue. I would appreciate any help.
