Old Dec 13, 2020 | 02:23 PM
a12052's Avatar
a12052
Default 2007 Crossfire Coupe - No Start
Hello fellow Crossfire Warriors! This is my first post after owning my Crossfire for 10 years with no issues. Now having the infamous no start condition. I have read the other posts and have a new RCM ordered and moving on to Cam/Crank sensor replacement next (potentially), but wanted to post where I am in the process for potential help:
Current Symptoms- Turn ignition on, all dashboard warning lights come on, engine does not turn over, battery fully charged and less than two years old, engine fan does not come on after ~30 seconds with key in on position. Checked RCM fuses, re-solder 3 common points on RCM, no change. Checked battery ground, no issues. Small fan in compartment where RCM sits runs with key in on position.
The Past
Recently having issue where would not start right away. Would try to start, nothing, try again, then after 3-4 times would start up. Last time the car ran it started acting up as I took it out of the garage (dashboard lights on), drove it back into the garage, diagnosed alternator failure as it would idle fine but ran battery dead, then would not go out of Park. Replaced alternator and started up once, same issue at that time, would not shift out of park. Now no start even after 5-6 times of trying to start.
Anyone with ideas let me know.
