Thread: Battery drain
Old Dec 30, 2020 | 10:32 AM
ZERACER
Default Re: Battery drain
One cause is the alarm siren shorting out because the old batteries inside go bad and leak acid. You can remove it or replace it. It is located under the cowl in front of the windshield. You need to remove the wiper arms first. Clean the drains while the cowl is off.
