Hi,
I need to replace one of the transmission cooler oil line that goes into the radiator but no longer available from dealer. I went to an hydraulic repair shop, but they won't do that kind of work ???
So I want to make one myself but I don't know the type of fittings MB uses.
This end goes .... (This line needs to be replace)
to that flexible hose .....
And this banjo fitting to the other end of the rigid line at the radiator:
In picture 1 and 2, what type of fitting is this ? DIN, JIC 37º or else ??? Can I silver solder hydraulic lines ?? I need to find the fitting in the first picture because the banjo fitting is pretty obvious !
Thank you !
