Old Jan 17, 2021 | 09:49 AM
phil alvirez's Avatar
phil alvirez
Default crossfire battery: my experience
this is in case you want to know the condition of your battery.
this is my experience.
am bringing it in hope that there is something that is of some use to anybody. if any1 has different experience and wants to talk about this subject too, you can start a post anytime, as i did. or if any1 wants to discuss or ask anything in more detail, please feel free to reach me at my address. just click at my name at the left upper corner, send me a private message.
when i got my xf and found this forum, i also learned that the battery is subject to lots of demands from the many components of the car, including the computer, and began a quest that has brought interesting results. this is to share with all what i have learned.
before, all that i knew regarding the battery in a car, was that the moment it takes longer to start, you have to buy a new 1 asap, or you run the risk of getting stranded. period. no data, technical or otherwise. so i began to investigate. like: a 12 volts battery is 12.6, not just 12 v. and whatever below that figure is no good for the battery: it shortens its life to be below it.
i found this chart: https://www.pinterest.ca/pin/299770918947414570/
so i searched for a tester. found this:
Amazon Amazon
simple to use, low cost, and with items that i couldnt find in others that are way more expensive. with it i learned many things that didnt know existed, and have changed my knowledge of the situation beyond my wildest dream. now i know all that i need about it.
at the time i got it i put it to my battery and was shocked! the tester tells you if the battery is good; if it is low and has to be recharged, or that it has to be replaced. and it told me that it was no good and had to be replaced. it was practically discharged: it showed 11.8 volts ! and when a battery gets discharged that low, it is not a matter of charging: it is telling that something is wrong, and you have to find out and take the necessary steps to correct it. also, at this time it was exactly 4 years old, and i had been warned that it had to be replaced at 4 years. so i got a replacement.
i was told that an AGM is better so i got 1 and installed in my car. later i learned that the reason was telling me that it had to be replaced was that the SOH was low.
as the old 1 was going to be recycled, i got the idea of using it for tests that otherwise i wouldnt dare to do with the good 1. the 1st thing i did was write down the figures the tester provided, even if at the time i didnt know a thing about them. then charged it overnight. it went up to 12.6 v. then placed in storage for some time. and when i checked it from time to time i was surprised that kept the charge. didnt expect this, so i was curious. the charger that i got, even low cost, seemed to fulfill my needs. i was to learn that it was a great decision.
Amazon Amazon
then i decided to try the option that says: "restore" (it shows "PUL" at the screen, meaning pulse). it stops when done. and to my surprise, it reads 13 volts. after letting it rest so i could get more realistic figures, i took all that it collects and compared with the previous, when it was discharged. these are the readings that this tester provides: volts; CCA; SOC; SOH, IR.
from wiki: State of health (SoH) is a figure of merit of the condition of a battery (or a cell, or a battery pack), compared to its ideal conditions. The units of SoH are percent points (100% = the battery's conditions match the battery's specifications). typically, a battery's SoH will be 100% at the time of manufacture and will decrease over time and use. However, a battery's performance at the time of manufacture may not meet its specifications, in which case its initial SoH will be less than 100%.
State of charge (SoC) is the level of charge of an electric battery relative to its capacity. The units of SoC are percentage points (0% = empty; 100% = full)
Cold cranking amperes (CCA): the amount of current a battery can provide at 0 °F (−18 °C) for 30 seconds while maintaining a voltage of at least 7.2 volts. ... For example, a 250 CCA battery will have more starting power than a 250 CA (or MCA) one, and likewise a 250 CA will have more than a 250 HCA one.
internal resistance:
When the power source delivers current, the measured voltage output is lower than the no-load voltage; the difference is the voltage drop (the product of current and resistance) caused by the internal resistance. The concept of internal resistance applies to all kinds of electrical sources and is useful for analyzing many types of electrical circuits.
the 1 that tells us if the charger is really doing something-and how much-is internal resistance (shown as 'res' in the screen). here i want to elaborate about the importance of internal resistance and sulfating. a battery gets sulfated as it goes. this means that some of the space is filled with sulfate, and this reduces the space for charging, so the figures get smaller. no more 12.6. and so on. and also, the internal resistance increases. and, as with this tester you have these figures available, you can measure the desulfating. so far, i havent found any source that sells chargers that claim that desulfate, that can prove that their products really do so (and there are zillions of products that say they desulfate). and also, neither can tell how much. but with this humble tester we get that figure so we know that the charger is desulfating, and with the IR readings before and after you know how much.
in this case, the final figure would be next time i use this battery for a while and do the testing and compare with the last 1. so far sulfating seems the most important factor to hurt the performance of a battery, and there are serious studies that prove that pulse desulfating is the best bet: https://thesai.org/Downloads/Volume8...Desulfator.pdf
http://www.vershv.narod.ru/sdarticle.pdf the interesting thing of all of this is that the battery was low for supposedly old age. it could be recharged but still was not in good condition because it was sulfated. and there was no way to check this if we didnt have this tester that gets SOH. the key figure was the SOH. if it is low, no matter if volts seem ok, and even CCA, it will not hold.
and this is what the tester provided with SOH. it reflects the ability to deliver specified performance compared to a fresh battery. is a measure of long term capability. it shows how much available energy has been consumed and how much is left. on the other hand, SOC represents short term capability.
to make things easier to understand with an analogy, readings from SOH can be compared with readings of the odometer, and those of the SOC with the fuel gauge. problem is, that even if showing 100% here, this could be really 80%, as the readings are of a fuel tank that has shrunk to 80%. that is because it is measuring the usable % at the time, that has been sulfated (20% in this case), compared to the possible when not being sulfated. it is just to tell when it has reached its full charge possible.
then, when desulfated with pulses, it improved its condition above the standard. way above. it went up to 13 volts. way above the supposed normal figure. and it is a 4 years battery. this proves that the parameters specified by manufacturers and sellers, are their way to sell more, which is their goal. and the battery has still more life for a good time. a typical example of a way to have the best kept secrets. and so there are other examples. but here the subject is battery.
anyway, with this we know the condition of a battery. no guessing. cold numbers. data. the battery is no longer a mystery, and we have the means to keep it in good shape for a longer time.
more data here: https://www.crossfireforum.org/forum...-part-car.html
