Old Jan 17, 2021 | 01:40 PM
tighed1's Avatar
tighed1
Default Re: Bad PCM maybe???
Doug. Couple of things to try.
Can you hear the fuel pump run for 2 seconds when you first turn the key to the ON position? It's under the car near the passenger rear wheel.
Have you checked for fuel pressure on the fuel rail in the engine compartment?
Try spraying starter fluid (or something flammable) into the intake and see if the car runs while you are spraying.
What happens?
