GraphiteGhost
Did some maintenance yesterday. Rotated fronts (L-R, R-L) and rears (again L-R,R-L). While off the car cleaned inside rims, inspected suspension/brakes/stabilizer mounts (both rear sides). Totally surprised the F & R brake pads, doesn't look like any wear! All good, updated logbook!
I may be a bit confused, but I was under the impression that you can't just rotate a radial tire. Because of the rotation direction, you would have to unmount and remount the tire to move to wear pattern to the "now outside". Please tell me if I'm not correct in that the geometry of moving one wheel to the opposite side of a car doesn't change the "direction" of travel for the tread.
