Old Jan 31, 2021 | 12:10 PM
  #224 (permalink)
sk8erjosh09's Avatar
sk8erjosh09
Default Re: Let's discuss the key fob transponder chip(s)
I have two functional fobs, what I would like is a simple key with the chip installed in it. It would basically just manually open and close the door and start the car. This seems a simple enough answer if the chips can be made, is it possible someone can do it?
Yeah, I will be able to in a week or so (waiting on key maker that’s en route) and it sounds like Viper can (as well as SOS and Needswings). That’s the ‘valet key’.
Back to the SKREEM updates.
I successfully pulled and read the processor, and the EEprom. I can’t figure out why it doesn’t communicate though. There’s no visible damage or obviously bad data. I need to test/pull data from a working one. Does anyone have a known good one as a spare they can send me?
I want to clone the data from a good one and write it to the 3 bad ones I have. If it’s a data problem this will fix it and allow them to work provided the VIN is useless like in the ECU’s.
