Old Feb 7, 2021 | 11:14 AM
Robertwav1's Avatar
Robertwav1
Default Re: Fan resistor bank goes bad....a little scary!
Does this sentence really say what happened or is it just an assumption? The battery and resistor was OK when starting the car so the resistor had to fail between starting the car and before the heater was turned on, or am I missing something?
Okay, here is the scenerio. Went to start the car the next morning, the battery was completely dead. Hooked up one of those battery starters and immediately the fan came on with the fan switch in the off position. Apparently internally the resistor shorted to ground and the fan was energized thus draining the battery overnite with the ignition off.
