Old Feb 15, 2021 | 11:59 AM
UrbanE's Avatar
UrbanE
Default Re: Drivers Seat Removal Problem
Originally Posted by Jack G
No, I have not because all the other seat functions (up/down/tilt) work. I have been assuming a single relay provides 12v to all the motor switches. If each motor has a separate relay then your suggestion is a good one. If this is correct, where is the forward/back motor relay located?
Do you know which connector goes to the forward/back motor? Knowing this might allow bypassing the switch and apply 12v directly to the motor.
Thanks,
Jack
Have you downloaded a copy of the manual? If you have a copy, then it’s best to review the area in question.
always best to be as aware of the situation on your own before you dive into this.
it’s usually faster this way too.
