Old Feb 15, 2021 | 09:50 PM
Jack G's Avatar
Jack G
Default Re: Drivers Seat Removal Problem
I plan on removing the 2 fasteners that attach the seat belt bracket to the seat rail. If that can be removed it might reveal the rear screw holding the main stationary rail. I looks like this bracket is also pinned to the frame. If necessary I can drill out the pin which will release the bracket. I also noticed a bracket held on with 2 screws that looks like it might hold the pinion gear that rides on the rack. If the pinion gear can be released this will possibly allow raising the gear off the rack and allow moving the seat. Are there any layouts, diagrams, or photos showing the location of the forward/reverse motor? All the documentation shows electrical block diagrams. It might also help to know which connector goes to this motor or what the wire colors are. I might be able to connect 12v directly to the motor and move the seat.
