Jack G
Thanks for the photo. The upper motor in photo appears to be for the forward/rearward drive which includes a reduction gear box. This looks similar to the driver's side seat. There are 2 screws attaching this unit to the seat rail. It looks like the output shaft from this drive connects with the rack mounted to the bottom track. If after removing the 2 screws supporting the motor and gear box to the seat frame, I might be able to slide the drive unit away or disconnect it from the rail. If this happens I will be able to manually move the seat forward. Another question, what color connector connects with the upper motor?
Thanks, Jack
Jack, is there ANY way to tap into the plug for the forward/backward motor and momentarily apply power to it to move it enough to access the track bolts? It would only require a 12v battery and some wire attached to the motor plug connector. They are D/C motors and looks like they go until they run into the end of the track (no limit switch cutoff). Just be careful not to touch the battery post until your sure the connections are solid and EVERYTHING is clear of the moving seat. IF it is going the wrong direction, just reverse the wires at the battery.
Most important, keep clear when applying the power!
