Re: Bad PCM maybe???
Pizzaguy...
It took three tries of three to do it, but it worked. The first set of three did nothing. Then thought maybe it was because I did not have the engine on...you know how that went...thought I screwed up the car. Tried another set of three again with the car off. The latch for the back of the top disengaged but nothing else. Figure I would try a third set of three as I had nothing to lose and was getting at least some results. After the third rotation turned the windshield latch but the windows did not go down! Was worried but figured that it would not hurt if I just put down the windows and tired again and it worked perfectly. Not sure why it happened this way but in the end it worked. Cycled through it about six times and it seems to be working fine though the first two time the front of the top came down by gravity and not controlled and so on the third and fourth I supported it and then the fifth time it seemed to be under better control...Anyhow I now have a working top, a working spoiler, and a partially working Crossfire.
Next issue is the rear window...what process would you recommend on gluing the window back on.
Thanks again
Doug
