Old Feb 23, 2021 | 03:35 AM
onehundred80
Default Re: Sooo...any tips to get the rear weather stripping back on when changing the top?
Originally Posted by jason_cruse
I'm talking about the thick part on the rear of the top that's all one piece with the weatherstripping that seals the rear bow to the tonneau cover. It came out easy enough, but there is a metal frame under the rubber, and no matter how I try to get it back into the channels, and beat on it with a rubber mallet, it just won't go back in. All the videos online explain how hard it is, and then they cut away to it being finished (I imagine there was a lot of cussing if it's gone anything like mine) . Any tips would be greatly appreciated!!!
If it is “T” shaped like the seal at the bottom of the doors, you put silicon lube on it and use a credit card to push it in, and you just push on anything still poking out with your fingers.
