Old Mar 1, 2021 | 12:31 PM
richb55's Avatar
richb55
Default Re: Clunking sound right front
Originally Posted by Toolman
Unless it is recurring sound/incident, caused by a worn part, I suspect your tire picked up or flipped something to cause it to hit the underside of the car. As you were focused on doing a lane change maybe there was a small pothole you hit without realizing it.
check and see if your coil springs did not snap off at bottom , it’s a common problem
