Re: Electrical Wiring
I wired mine to a switch under the dash, which is wired to battery. The wires run under the trim along the driver's side. I got power from the fuse box under the hood - there is a cool channel from the back of that fuse box into the cavity above the clutch/brake pedals. I picked up my ground from a screw under the dash as well.
Not sure who you can get up there,
