Old Mar 23, 2021 | 02:23 PM
mariontr's Avatar
mariontr
Default Re: P0444 with Check Engine Light
Originally Posted by mariontr
Ok, got the purge valve solenoid hose from Rob at NeedsWings and now have run into a problem had to cut the hose since could not get the clic clamp off now it is stuck on the tubing at the bottom. Has anyone taken one off? See the attached pic.
how to I get the lower clic clamp off
any problems with driving without this hose attached to the solenoid?
Folks an update, was able to get the bottom part of the hose off with a long extended reach needle nose pliers. The clic clamp that was attached from the factory was put on it in such a way that it was too close to the ac line, seems it also had some type of glue on the rubber itself that sealed itself to the metal tubing. Once that was resolved put on the new hose and used two zip ties at the bottom took it out for a couple of miles (15) at varying speeds and so far no check engine light. So what was changed was the purge valve solenoid, hose from NeedsWings, new gas cap. In case any one is interested the hose has the following stamped on it MB A 170 476 51 26 V Q2 and measures point 32 inches (8mm) ID (inside diameter) and .55 inches (14mm) OD (outside diameter).
Last edited by mariontr; Mar 23, 2021 at 02:27 PM. Reason: correct spelling of Needs Wings
