russthemuss
thanks for this help and info, do i just pull the pins straight out or do they need to turn a certain way to get them out, can i get to the fuel level sensor with just taking of side panel, sorry for these questions just need to know before if i found no leak where else might then smell of fuel be coming from, could the fuel cap not fitting tight be causing it do you know?, thanks
Did you check all the hoses around the fuel pump and filter? That is easily accessible when the car is on a lift, you only have to remove a plastic access panel.
