Old Apr 2, 2021 | 05:56 PM
onehundred80
Default Re: boot/trunk strip out
Originally Posted by russthemuss
thanks for this help and info, do i just pull the pins straight out or do they need to turn a certain way to get them out, can i get to the fuel level sensor with just taking of side panel, sorry for these questions just need to know before if i found no leak where else might then smell of fuel be coming from, could the fuel cap not fitting tight be causing it do you know?, thanks
Just pull the centre pin straight out and then pull the main pin straight out.
Leakage outside the car often leaves tell tale signs on the driveway. Go at it slowly and maybe save time in the end.
