Old Apr 5, 2021 | 05:27 PM
Mikey208's Avatar
Mikey208
Default Re: Possible Oil Leak
Those are the breather covers and they leak on most Crossfires due to the lousy sealant used at the factory. My Graphite never leaked but it was a daily driver - that seems to help.
There are no gaskets, they are sealed with "Ultra Black RTV", well, when WE seal them, they are. I did mine at around 32,000 miles and have 56,000 after five years, no oil leaking and my engine has stayed clean.
When you do the work, it is best to yank the entire valve/breather assemblies off and completely clean them after separating them. You then seal the breathers to the valve covers with RTV.
When putting them back on, use new valve cover gaskets and a new set of bolts. Needswings sells a kit for this very job.
Plan to do the fix the first time by just resealing the breathers to the valve covers. Then, six months later, do it again but do it MY way and fix it for good.
You can read the entire saga of how others have had to fix theirs more than once, like I did, and learn from it here at the link below - I think my story starts around post 232 or 250. I'd never tried a job like this before and actually enjoyed the process. It took me HOURS over two weekends, mostly to give parts time to dry between steps.
https://www.crossfireforum.org/forum...over-leak.html
Wow! Thanks so much! I can take care of that. I've done things like this many times over the years but with the older cars. And you are correct in what you say about doing the right way the first time. That way you don't have to go back and do it over.
