phil alvirez
there is a device that tells the tire pressure without having to remove the existing parts-that need to remove the tire to replace them-and calibrate them.
these just bolt into the tire pivot.
and cheaper than the others.
has any1 seen them, and better still, has installed them?
https://www.amazon.ca/dp/B08D9KBRR6/...KS87V57X4JCPT0
I have been using that since December 2019. Works great. No problems. Even though I keep my Crossfire garaged, the batteries in that device keep a charge for several months. I replaced the “watch” battery in each screw-on sensor after one year but they were still working fine.
I prefer to see the actual tire pressure readings rather than just a warning light coming on. The readings that I get on each tire matches two different digital gauges that I have. I had the original TPMS sensors removed from each tire when I bought new tires last August. A piece of black plastic tape over the TPMS dashboard light works fine. I intended to disable the TPMS light when I was replacing the overhead map lights with red LEDs last week. But just ran out of time.
