Old Apr 15, 2021 | 04:51 PM
YAMAHA's Avatar
YAMAHA
Exclamation Hot start Problem :(
hello everyone is my first message here. my car has been having a hard time running while it was hot for a long time. Starts quickly when cold or on first run. But when I go to the market or anywhere and try to start it after 20-30 minutes after the engine reaches its normal temperature, the cranking time is prolonged. sometimes it even feels like it won't work (as if it is choking). There hasn't been a moment when it hasn't worked. No problem idling with normal travel and high speeds. I suspected the petrol filter / regulator and changed it, but it didn't work. If I can add a video below, you can see it. Thank you in advance for your help.
My car only has a hot start problem.
https://streamable.com/5jb9xw
https://streamable.com/elfj60
