CyberCG
My turn signal problem turned out to be self inflicted. I had totally removed all the dash and console plastic panels for painting. I discovered that during reassembly, the Emergency Flasher wiring connector did not properly click into place. This caused an intermittent connection that would cause the turn signals to not operate at times. I properly seated the connector and now the turn signals work as they should.
Thank for letting us know and happy you solved the problem. What kind of paint did you use for the plastic panels? Were they worn out?
