Old Apr 17, 2021 | 09:20 AM
dedwards0323
Default Re: when battery light comes on
Originally Posted by phil alvirez
what could be happening?
it began happening to me yesterday. it last for a few seconds. checked the battery and all is o k. volts, amps, CCA, SOC, SOH. everything.
then today again. this time was for some 5 minutes when on the expressway and when reached a stop it was gone. did not come back when driving for a while.
my battery is 1 year old and kept in best shape. when running, the alternator gives constant readings that show 14 amps. even at a stop.
if anybody has experience with these symptoms, advice will be appreciated.
Looks like you are using a battery tester like
<b>THESE</b> THESE
, which is good for determining overall battery condition. I would tend to agree with those that point to an alternator issue. A functional failure with the alternator has surfaced. The functional failure being defined as "inability to adequately provide/sustain charging capability to the electrical system". That failure mode could be caused by a number of faults, One could be simply a slipping belt condition, which is easily fixed. Take a close look at the drive belt to see if you see any signs of fatigue (stress cracks along the webbing). Change the belt if you finds this failure mode. Most direct alternator failures are addressed by a new alternator; rebuilt parts industry has made this somewhat economical to us DIYers. . You could remove the alternator & have it checked by a service shop that specializes in alternator & starter rebuilds. These shops have the capability to check the alternator under load. I've got one near to me that I've used occasionally. Good luck with your ongoing diagnosis & repair.
