Thread: rough shifting
Old Apr 23, 2021 | 01:39 AM
phil alvirez's Avatar
phil alvirez
Default Re: rough shifting
just found here this: https://www.yourmechanic.com/questio...-move-by-sue-b
"When a shifter becomes hard to move, it is usually the interlock cable. AKA,shift cable. This cable slides in a housing and connects directly to the transmission. When this cables becomes worn, it gets hard to move inside the housing. There is also a shift lever assembly, which is what you are grabbing when you move your car in and out of gear. Both of these are the main culprits with hard to move shifters. "
will try to find it in mercedes forums.
