Old May 10, 2021 | 02:11 PM
onehundred80
Default Re: Problems Crysler Crossfire
Originally Posted by Coedfan
Hi I am a new member with a 2006 Crossfire. I had a new RCM a few years ago which I have looked at and it looks perfect. I got my car out of the garage for its MOT in the Uk (it had not been used for a year because of Covid). It ran fine for 2 days and then I have the following problems:
1. Engine cranks but does not start.
2. The key remote does not operate the door locking system. (I put new batteries in).
3. The indicate light flashes and all consul lights come on.
4. The boot and doors do not lock.
All the time I have started it when not used it had no problems.
I wander if it is a scram unit and is that easy to get and put in.
If anyone can assist me I would be so grateful. Regards Noel.
The remote loses its programming when the batteries have died or have been out for some time, it has to be reprogrammed after the new batteries are in, you can do it yourself as the instructions to do it are on this forum.
When the doors do not open using the fob they will not close using the fob. You should be able to open and lock the doors manually using the key.
Maybe the Crankshaft Position Sensor has failed or the connection has corroded,,only buy a Bosch CPS.
Have you checked for any codes being set, is the engine error light on?
