Old May 10, 2021 | 04:25 PM
Mikey208's Avatar
Mikey208
Thumbs up Re: blown turn signal bulb, or not?
Originally Posted by vpats
I thought I’d throw this out, I didn’t see anything posted referring to this exact issue. My right side (passenger) side turn signal bulb quit working. When turning the right signals on, it would blink very fast, the rear signal worked but the front was out. Thinking it was a simple bulb replacement; I bought a couple of new bulbs.
I pulled the bulb assembly and removed the old bulb and holding it up to the light, it really didn’t look blown. Since I already had new bulbs, I put one in and replaced the bulb assembly into the headlight module.
Starting the car and hitting the lever, the problem was still with me, rear worked and the front didn’t. Hummmm? Now what? I pulled the bulb assembly back out and as I was looking it over I noticed a small metal contact point on the side of the bulb assembly. Using my fingernail, I gently (GENTLY) pulled it out at tad (less than a 64th of in inch) and put in back in the headlight module.
Eureka! It worked. I don’t know how it would lose the connection, I mean it just sits there and does nothing. The point is, before you spend big bucks, take a look at this solution. It worked for me.
Wow! My exact issue! I have put two bulbs in it so far and it's doing it again. I love this forum!
