Doc78
Hi,
I will try to help.
1) Are you using your FOB to lock the doors?
2) Are the doors locking when you use the fob?
3) What fuses did you change that blew? This will help us determine issues. If the card is no longer present in your fuse box under the hood or dash there is a thread here that will lead you to the fuse numbers.
4) I would check under your seat and see if the floor is wet.
5) open your trunk and open the cover to your jack. Looking at the foam black pieces stick a piece of paper all the way down till you hit bottom down the far right side of the black foam pieces and if the paper comes back wet then we have a few more answers and can help with that issue as well.
There are people way batter at this than I am but this will get everyone started.
@Doc78
Thank you for your message
if I lock the car using the fob the car does lock but after half a minute the indicators start flashing (no alarm sound) but if I lock the car using key in door way then it also locks the car but this way the indicators don’t start flashing
the blown fuses are 2x 5amp fuses and 1x red 10amp fuse
im looking at other threads on here regarding the spoiler not working but everyone’s issue is the same where the spoiler doesn’t work and the manual spoiler button just flashes red but mine is completely dead there’s no lights at all when pressing the manual spoiler button 🤷♀️
as for the electric seats so the only option I have is to remove the seat? I did touch the floor under steering and behind the seat floor and it all seems dry and defiantly isn’t wet
Thanks
