Old Jun 1, 2021 | 11:50 AM
onehundred80
Default Re: Spoiler has no power and electric seats don’t work.. HELP 😭
Originally Posted by Bob0121
Hello, I’m new to this forum and I was hoping someone can give me some advice on the issues with my car.
so I bought myself a Chrysler crossfire coupe a few days ago but the car has 3 issues which are the following:
1- The electric seats do not work
2- rear spoiler does not work( stuck open )
3- when I use the central locking to lock the car I get the indicators flashing with no alarm sound but when I lock the car manually using the key then it’s fine the indicators don’t flash
I’ve had a look at the fuses and the red 10amp and two 5amp fuses are blown I’ve changed them which made no difference and blew out again
the spoiler has no power in it at all so there’s no red light flashing on the manual spoiler button on the centre console I was thinking the spoiler motor has failed but if that was the case shouldn’t there still be power showing on the manual button as in the red light
any advice would be much appreciated
Thanks
Your item #3 is correct in the way you describe, nothing wrong.
The cars did not come with a beeping alarm, the beeping alarm was added later when the original alarm failed or they just wanted to hear a beep.
The seat relay may be broken, it can be replaced or sometimes repaired. It could be a fuse or a bad wiring issue.
You later post adds more information that should have been here, nobody can give an answer if vital info is missing.
