Doc78
I got a picture that had three arrows pointing to fuses 6,7 and 9.
I will say now your buzzer is bad If fuse 9 is blown try replacing it (and do the same thing with the door) happens a lot and a great thread here to replace repair the buzzer.
If you replace fuse 9 and the siren works then you know but if it blows the fuse again Id disconnect the siren and see if fuse 9 blows again after you replace it.
fuse 5 is your radio and fuse 10 is your speed control.
I edited my last post to have more info on BCM issues.
Hope I helped
thanks for the info so basically fuse 9 is the buzzer.. I don’t understand how the fuse for radio is blown as the radio still works fine so that doesn’t make sense 🤷♀️
as you’ve said fuse 10 is speed control I’m guessing that’s the spoiler? Can you clear one thing for me if the spoiler motor is blown does the manual spoiler button in centre console still flash red when pressed? As mine does nothing when I press the manual button no light
