Old Jun 1, 2021 | 07:37 PM
onehundred80
Default Re: Spoiler has no power and electric seats don’t work.. HELP 😭
Originally Posted by Doc78
I downloaded your manual and let’s see if I can clarify my comments here.
I think you are mistaken on the fuse numbers you have the arrows by on your picture.
when I look at the picture I see fuse 6,7and 9 with arrows beside it.
by your manual 6 controls your mirrors, 7 is bcm and a few other items.and 9 is buzzer and dome light and a few other things.
that’s why I would start by pulling the BCM and opening it up and check for corrosion and the solder connections. If it looks bad please refer to the link I sent earlier to get it repaired.
Id also pull the buzzer replace fuse 9 and see if it blows again if so we have a short somewhere else.
again just trying to help.
We do not call it a buzzer, it is an alarm or a siren. People added buzzers from Radio Shack etc. before the chirping alarm was introduced to the members here.
The BCM should not be damaged my moisture it is high under the hood and well covered.
