Old Jun 2, 2021 | 04:29 AM
Bob0121's Avatar
Bob0121
Default Re: Spoiler has no power and electric seats don’t work.. HELP 😭
Originally Posted by Doc78
I downloaded your manual and let’s see if I can clarify my comments here.
I think you are mistaken on the fuse numbers you have the arrows by on your picture.
when I look at the picture I see fuse 6,7and 9 with arrows beside it.
by your manual 6 controls your mirrors, 7 is bcm and a few other items.and 9 is buzzer and dome light and a few other things.
that’s why I would start by pulling the BCM and opening it up and check for corrosion and the solder connections. If it looks bad please refer to the link I sent earlier to get it repaired.
Id also pull the buzzer replace fuse 9 and see if it blows again if so we have a short somewhere else.
again just trying to help.
Thanks for the information
so fuse 6 is mirrors
fuse 7 is BCM
Fuse 9 Is buzzer
someone else on here said fuse 9 was speed control but anyway you said fuse 6 is mirrors but both of my mirrors are working fine? 🤷‍♀️
either way first things first I need to remove the BCM and have a look at that from inside
