Old Jun 2, 2021 | 07:38 AM
zip439's Avatar
zip439
Default Re: Spoiler has no power and electric seats don’t work.. HELP 😭
Originally Posted by Bob0121
Thanks for the information
so fuse 6 is mirrors
fuse 7 is BCM
Fuse 9 Is buzzer
someone else on here said fuse 9 was speed control but anyway you said fuse 6 is mirrors but both of my mirrors are working fine? 🤷‍♀️
either way first things first I need to remove the BCM and have a look at that from inside
NO NO NO The first thing you need to do is take the windshield wipers off, remove the plastic cowl that runs under the windshield and you will see the SIREN ( STOP calling it a BUZZER) and disconnect the damn siren!. Insert a new fuse nine and start your car. You can run around forever without the siren connected. Many of us do just that. It will not effect anything else, but it does eliminate some problems. you just won't have a security siren/alarm.
While you have the cowl off, clean out the four drains which allow water to run down and out the bottom of the car!
