Old Jun 2, 2021 | 12:12 PM
Daisyd's Avatar
Daisyd
Default Re: Whining Sound In Engine Bay
Originally Posted by Sexy Back
I have a 2005 Crossfire Limited with 87K miles and recently noticed a whining noise coming from in front of the engine, more towards the alternator side (power steering pump pulley side is good). Sounds like a turbo is spooling up when I accelerate. Can be repeated when parked and revving the engine. I replaced the water pump and serpentine belt back in December. Just a slight leak from one of the top bolts on the water pump but that could be gasket issue or bolt is not torqued enough. I did notice the tensioner pulley assembly wiggles rotationally a bit while it is running. Could that be the issue or has it caused the alternator bearing to go bad? Should I replace the alternator and the tensioner pulley?
Did you ever find your issue? I have to remove my belt today and check all bearings and pulleys. I hope you found your issue because this sound is annoying
