Old Jun 23, 2021 | 05:40 PM
Doc78's Avatar
Doc78
Default Re: '04 hard lurch putting in gear, too many lights, 31K
Originally Posted by Bigtoyz
Doc78, where is this one and only main ground you mentioned? It does seem like I wire brushed this early on without success but I certainly would try it (again?). Onehundred80 mentioned replacing solenoids, which I didnt do when I replaced the conductor plate, but would be willing to try that. I dont have a manual for the car. Any suggestions where I can find a manual? If I read right, there are 6 trans solenoids? Replace all 6 or are there certain ones that cause this? The RPMS dont rise, it does seem like the bands tighten down more than necessary and there is little slip, leaving a hard launch. I would like to replace the solenoids with OEM, they are $50per, but if thats what it takes.
Great suggestions guys! I really appreciate all the help.
The ground runs from the transmission to the chassis on the drivers side can’t miss it.
If you click the link on 180’s signature line it will take to the page to find the manuals.
