Old Jun 30, 2021 | 07:55 PM
pizzaguy
Default Re: Engine Remains On After Key Is Removed
So there is no module in the underhood fuse box or the large box next to the battery? Keep in mind that all of the connections needed for a remote start can also be found under the hood - it is not 100% required that the remote start be installed near the ignition switch - altho that is where most put them.
You have a bridge between battery feed and switched ignition that is interrupted by pressing the brake pedal - sounds like a remote start or pushbutton start kit to me. Of course, ANY bridge between battery hot and switched ignition would explain this - but the fact that pressing the brakes shuts the car off certainly implies a remote- or pushbutton-start.
