Old Jul 7, 2021 | 06:43 PM
pizzaguy
Default Re: Crossfire top problem
Originally Posted by lpw47lpw
Watched all and can do top will go up after manually putting down but not down again only manually have not removed fuse 5 does car need to be running
since it works going up after putting down manually couls cargo sensor be bad?…heip
THis is an easy one; either the divider ("cargo") sensor is bad (and it probably is) or the top open switch over the passenger's head is bad.
Gotta be one or the other. Open the trunk and make SURE the arm on the divider, driver's side, is pressing up on the switch arm.
