Old Jul 10, 2021 | 12:59 AM
nemiro's Avatar
nemiro
Default Re: M113K Into a Crossfire - Journal
This post will be reserved for part numbers, links and other useful acquisition information. It will be edited as I get information to post into it.
Most everyone knows, but since I referenced it, find good deals on cars and parts from Craigslist. You'll be amazed at how many Crossfire related things you will find!
Engine, fueling, cooling, electronics:
  • Tuning and electronics setup by Josh Chase at the Mercedes Swap Shop
  • Fuel Pump from S65, but also from several others. Mercedes-Benz S65 AMG Pierburg Fuel Pump 7.00228.51.0 0014706594. I got mine from eBay, good results. Pierburg Fuel Pump on eBay
  • Many parts from RockAuto <- if you're not shopping there already, great prices on a ton of stuff for our cars. There are discount codes for 5% off everyday, so search for the codes (they expire periodically, but there's always a new one).
    • Air Filters HASTINGS / BALDWINAF1290
    • Supercharger belt GATESK080507RPM
    • Accessory Belt GATESK060970
    • Spark Plugs NGK93893
    • Idler Pulley DAYCO89161
    • Belt Tensioner ÜRO PARTS1122000970
    • Intake Manifold Gasket MAHLEMS19439
    • Water Pump ÜRO PARTS1132000101
    • Exhaust Manifold Gaskets MAHLEMS19393 Actually a set of 6 for SRT6, but the same. They were not in stock for the M113K, so I ordered these
    • A/C Filter Drier FOUR SEASONS83093A Crossfire part that I will replace, as I will have the system evacuated, and recharged, anyway
    • Oil Cooler Gasket AJUSA01192950
  • Victory Road Performance
  • AN Fittings, silicon hose, oil cooler, fans, etc. Fantastic & cheap source for these parts and a lot more! Silicone Intakes
  • Stainless Steel -6 AN bungs for looping the fuel rail
    Amazon Amazon
Transmission:
Whatever It Takes Transmission Parts, Inc. When you call to order, ask to setup an account. Do it. It will save you nearly 50% on the cost of parts!
  • 78002A Transmission Seal Kit
  • D78446C Conductor Plate
  • A78137AHPK Alto Friction/Steel Module Kit for 722.6
  • T78165A TransGo shift improvement kit
  • DYD2120B Torque Converter
You are looking at a little over $1200 for these parts in 2021 dollars, FWIW.
Rear Axle:
New SRT-6 Driveshaft. Click Here for Info.
