Re: Sticky Ignition Key Fix for all Crossfires 2004 thru 2006
After an epic struggle, my ignition key assembly is sitting on the kitchen counter (no wife)
Had to grind down the release lock pin.
The key was stuck in 0 or 1 position,
I could not remove the black key tumbler
The key is now out and I can rotate the tumbler to all positions.
Should not the key spring back to run after going to start and releasing the key?
Before re-installing the key assembly, I would like to do a "is every thing working OK"
Could someone be kind enough to refer me to a post number the includes a check list.
Do I have to worry about the locking pin that I ground down?
TY Rupert
Reason: better choice of word
