Old Jul 16, 2021 | 03:30 PM
latemodel21's Avatar
latemodel21
Default Re: Drink Spill In Gear Shifter
Originally Posted by Cub Fan
Do I need to clear any codes or will the car self clear once it reads the “new” assembly?
@philosophico Noted. My next mod is to remove the cup holder and make a bin. ….that and treat the car like Gizmo so it doesn’t turn into a Gremlin!
Be Safe. Be well.
The car should happily accept the new shifter without the need to xfer any settings or programming. HOWEVER, there are some shifter malfunctions that can create a a stored error that must be cleared (I have personally only seen this once). SO, if you replace the shifter and still have some problem, you may need to hook up a dealer level tool and clear a code .
HTH,
Chris
