Re: Replaced all hydraulic now top not working
Ok guys here is an update, I took the car to a shop here in Miami. They hooked it up to the computer the error that's showing up is the the main lift sensors are not picking up the metal rod, now you do a simulation by running a piece of metal by it and it picks up the metal. Another test is you loosen the sensors and move it over the rod and it picks it until about an inch or two away but as soon as you put them on the cylinder will not sense the metal. So I ordered 2 new sensors and installed still having the same issue. I'm going to take out the main cylinder and send it back to Klaus to check it out, but he doesn't think that the cylinder is the problem. Have you guys ever heard of this before. Any ideas because we r stumped on this one.
